I hope this isn’t a repeat question. Is there any way possible to forward GPS data to the global broadcast IP - 255.255.255.255? Typically we wouldn’t need this, but we’re hitting an issue where a particular business unit needs to use SpeedFusion VPN which means unique LAN networks, which means I can’t just have them use the global config because each network broadcast IP would be different. Most of our vehicles have all the exact same LAN so it’s easy enough to put that particular broadcast IP into the bulk config and push it out.
If I could either forward GPS to the global broadcast, OR variabalize the GPS Forwarding IP and change it through the IP Settings field like I do my LAN IP that would literally solve the last problem I’m having with this deployment.
Thanks a ton for any advice!
