Does anyone know if it is possible to manually configure the location of a router in its’ configuration and have this static location forwarded to other systems using the GPS Forwarding option for the situation where a device doesn’t have a GPS antenna, can’t receive a signal or maybe isn’t even fitted with GPS at all?
The router will always forward the actual GPS location where the device is located with the valid GPS signal.
The request seen like invalid that the static location should be define at the GPS server end and not the router end.
Disconnect GPS puck if GPS reception is valid.
Then edit GPS Lat Long in Device details - see link below
