GPS Forwarding Adding Full Serial as Vehicle ID
Hello Peplink Community,
I am currently managing a fleet of over 1,400 MAX BR1 devices. For our tracking infrastructure, we rely on the GPS Forwarding feature to send NMEA sentences to a remote server.
To distinguish devices on the receiver side, we have historically used the “Vehicle ID” field, populating it with the last 4 bytes of the device serial number. However, these last 4 bytes of the serial number started to overlap and to resolve this problem I had to do changes on the receiver side, but also manually set the “Vehicle ID” to unique values - and this had to be done device by device!
These solutions might fix my current hurdles, but I am not really sure if they’re scalable and universal in the future. What if I add a new device that ends the same as the values I have already set manually? This is not guaranteed and I will have to go through the process again and again… This adds a lot of overhead and scalability risk when dealing with large fleets.
The Request:
Is it possible in the next firmware updates to finally allow the full Serial Number to be used as the identifier in the NMEA sentence, rather than being limited to a 4-byte/4-character Vehicle ID? Alternatively, allowing the Router Name (which we already manage via InControl2) to be used as a variable in the GPS Forwarding settings would also solve this issue.
Has anyone else found a more automated way to handle this at scale, or is a firmware update the only path forward?
I look forward to hearing the community’s and Peplink Engineering’s thoughts.
I can foresee having this issue, even though I am only tracking one vehicle. The service I use accepts GPS packets from all US customers on a single IP address and port. So I could encounter a case where another one of their customers uses the same 4-character code that I’ve chosen. They call that field the IMEI, which would be unique to the modem. If the Peplink had the option to use the IMEI as the identifier that would solve the problem.
