Hi there…
how long are retained GPS data? IOW, how far in the past can I go? one week? one month? year? no limit?
thank you
S.
Hi there…
thank you
S.
Currently GPS data are kept for one year.
Hi, sorry to rewamp this topic…
I see that in IC2 I can’t go back in the past more than 30 days…
I refer to all datas available in Report section
for example today, oct. 4th, I can’t extract data from 01/09/2016 to 30/09/2016
the same if I try via IC2 API, even if I give the desired date…
is it a bug? a feature? I need to programmatically extract reports on month basis, and so I need to have full month available… is it feasible?
TIA
Sorry, currently the system only keeps 31 days of reporting data. We are working on keeping the data longer. Stay tuned.
