I have a Pepwave Max BR1 Classic, and I would like to use the ignition sensing feature to detect battery voltage at a remote location. I’m using firmware 8.0.2 build 3612. According to the manual for 8.0.2, the GPIO menu should be under “Advanced”, but it’s not there. I know the analog voltage sensing feature is in the works, but the ignition sensing feature should be there.
Am I looking in the wrong place? Do I need to enable this feature somehow?
The pepwave max user manual for 8.0.2 includes a section on the GPIO menu, so I thought it would be in 8.0.2. A note about the new firmware would help. No worries. I will try the 8.1.0 Beta 2 firmware. Thank you.
