Does pepwave have any router that supports IP passthrough with the following specs…
(note IP forwarding or drop in mode - but IP passthrough mode)
Need 2x Wan ethernet ports + LTE.
Needs to be able to support gigabit speed on the WAN
I can’t find any specs that list if they have IP passthrough or not.
Thanks!
@daniel.barnett, the IP Passthrough feature is usually found in a single cellular MAX series, eg. the MAX BR1 Pro 5G (with single Ethernet WAN) is a Gigabit performance router that you might want to consider.
Or, would you mind sharing your application use case that requires 2x Wan ethernet ports + LTE (or 5G)?
