Hello Peplink Team,
I have a question. Where can I enable geo-based SSID. So that SSID A is enabled when a device is in zone A and SSID is disabled when the device is in another zone.
Hello Peplink Team,
Use tags.
Configure your SSID to only broadcast when a certain tag is present on a device.
Configure a geofence to add or remove that tag as required, you can also use a tag to define which devices the geofence needs to apply to.
Thank you : )
