A running service was discovered (generic-service-open) during the penetration test. The Pentest team asked to disable the running service in Peplink. However, I cannot find any generic service on Peplink. My device is a Peplink Balance 580 with firmware version 6.3.4 2097.
You are several years behind in terms of firmware. Would you consider first upgrading (then re-run the pentest)?
noted.
