I upgraded my SFE CAM and FusionHub with 8.1.0 RC4.
How to enable the Dynamic Weighted Bonding algorithm?
Thank you
Navigate to the support.cgi page on your device and click the link below:
Which takes you back to the speedfusion profile page which you can edit to discover the Traffic distribution section:
Do I need to enable on both, the SFE and the FusionHub?
I don’t see “support” page, I thought I checked everywhere…
Oh, I am sorry, I just manually added the “support.cgi” to the url and was able to access that page on my FusionHub settings.
Now need to wait until my customer turns their SFE on to do the same on that device.
Thank you!
To access the support.cgi , you have to replace index.cgi with support.cgi in your webbrowser, while you are logedin into your Peplink device.
Thank you!!
