Hi everyone, I see the VM host requirements listed but not the VM itself. I’m looking to deploy FusionHub on Rogers IaaS in Canada which they said would work after I sent them all the details. This will basically be used with FusionHub Essential, just to bond maybe 2-4 LTE connections together to get at most 100Mbps. Rogers is saying I need to provide them with:
RAM Needed
Hard Drive Space Needed
Operating System
Just wondering what I’d need for Essential and FusionHub Pro. This would 95% be used for bonding or VPN fail over to start. Thanks!
I did but that says VM Host hardware, I’m asking the requirements for the VM itself. When I’m in VMware and I go to create a new virtual machine, I need to enter RAM, HD Size, and Operating System to create it.
If you use VMware ,select File > deploy OVF template and select the Fusionhub.OVA file the vsphere client will automatically have the correct settings.
You probably do have to edit the virtual machine settings to add a Network Adapter though after Fusionhub is installed.
The default settings after installation are:
OS: Ubuntu Linux (64-bit)
memory: 1024 MB
HD size: 16 GB (thin provisioned)
Great thanks, is there any reason I should get 2GB of ram? I assumed 1GB also but everyone keeps telling me that it’s way too little, but I feel like they are used to selling this for actual servers and what not where customers buy 8GB+. Not sure how RAM affects the router performance if we’re under 100Mbps.
