Hi all,
I’ve deployed a FusionHub VM with the following setup:
3x NICs in VMware
- 1x WAN
- 2x LAN
Currently, I’ve configured basic WAN and LAN connectivity successfully. However, I’m struggling to get multiple LAN interfaces working (whether as separate interfaces or VLAN-tagged).
Requirement: I need to segment traffic (e.g. corporate vs guest) on different LAN interfaces. The design is:
Branch → Hub via SpeedFusion VPN
Hub → downstream firewall for internet breakout
Separate LAN interfaces / VLANs on the Hub for traffic separation
Issue: FusionHub doesn’t seem to allow me to configure multiple LAN interfaces or properly utilise the additional NICs, even though they are present in VMware.
Question:
- Does FusionHub support multiple LAN interfaces directly, or is this expected to be done using VLANs on a single LAN interface? If VLANs, where do I add the additional VLANs?
- Are there any limitations or best practices when trying to achieve this kind of segmentation on FusionHub?
- Has anyone successfully implemented a similar design?
Any guidance would be appreciated.
Regards
