system
April 7, 2022, 11:43am
1
hi everyone.
I’m new here, and not much familliar with peplink products…
recently i saw, in Balance 1350, i have the option to define static route, subnet mask, with: 0.0.0.0/0 (subnet mask).
and in FusionHub, this option isn’t show up, (attached picture).
there is an option to define FusionHub static route, subnet mask to 0.0.0.0/0 ?
thank you!
We have seen in other areas where a 0.0.0.0/0 mask is not allowed that you can put in 2 entries.
0.0.0.0/1 and 128.0.0.0/1 which then covers the entire IP space,
But, there is already a default route on FusionHubs… The next hop route for the WAN interface.
So, how are using a FH where you would want a default route out the LAN interface? I’m not sure the two are independent route spaces.
When you have a LAN interface on the Fusionhub you can check the route PepVPN traffic to LAN checkbox and effectively set a default route for all remote peer traffic.
Otherwise the default route is the WAN gateway.
