Once the InControl subscription has ended for our complimentary FusionHub Solo licence, will it remain functional but without the ability to monitor or access it, or does it cease functioning completely?
Thank you
Your guess is right, the FusionHub Solo operation is not affected, only InControl 2 management will not be available for the device.
Hi @TK_Liew
Is it be possible to purchase an IC2 licence for FusionHub Solo or could this be paired with the IC2 licence/extended warranty of another physical device?
@SamuelNorris, you should able to purchase the IC2 Subscription from our online store from now onwards.
