Dears,
How can i replace my evaluation license to a solo license
Dears,
Hi - Welcome to the forum.
Backup your config file from the evail fusionhub. Destroy it. Build another fusionhub and apply the new solo license then apply the config file.
Hello Martin,
We exactly are in the same situation right now. Is your answer the only way we can achieve this? Can Peplink Support guys RA into the device and apply a fusionhub solo license and reboot it?
Best regards,
Yücel
the easiest way is download the config (backup), install a new FH with the new key and import the config.
Regards
Dennis
