Hi everyone,
I’d like to configure my FusionHub to allow remote sites to communicate and access each other.
My current configuration is…
FusionHub @ HQ behind Unifi Dream Machine - 10.10.9.1 (WAN IP ISP static, LAN IP 10.10.9.10)
Remote #1 BR2 - single VLAN 10.11.1.1
Remote #2 BR1 - single VLAN 10.12.1.1
My remote sites are able to establish connections with my FusionHub and their internet traffic is definitely being routed through HQ.
I cannot connect to any machines at HQ from remote sites or remote site machine to remote site machine.
I read that configuring static routes on each Peplink device to other sites would potentially solve this problem but maybe I’m not doing it correctly.
Any help would be appreciated.
Thank you.
If your remote sites both have a speedfusion VPN connection to the hub, then there is a configuration issue for sure.
Can you use the ping tool on each remote site and try and ping the LAN IP of the other remote site, the LAN IP of the fusionhub and teh LAN IP of the Dream machine.
Devices on your HQ LAN will not know how to route back to the 10.11.1.0 & 10.12.1.0 networks so you will either have to add static routes on the Dream machine for each remote network with a destination of the fusionhub 10.10.9.1, or you’ll need to use a routing protocol to let teh Fusionhub update the Dream machine about what networks it has available over VPN.
Screenshots of your status → Speedfusion uis on all devices would be helpful to diagnose further.
