FusionHub Performance: AWS vs On-Premise Deployment - Seeking Advice
Background & Current Setup
I’m located in Rwanda and have been testing FusionHub to bond multiple internet connections while obtaining a static IP address. I initially set up FusionHub on AWS (us-east-1, Virginia) but am experiencing significant performance degradation and considering moving to an on-premise solution.
Performance Test Results
Here are my speed test results showing the dramatic difference:
Direct Connection (SpaceX Starlink):
  • Download: 163.84 Mbps
  • Upload: 12.83 Mbps
  • Ping: 226ms
Through AWS FusionHub (Virginia):
  • Download: 65.80 Mbps (60% reduction)
  • Upload: 2.40 Mbps (81% reduction)
  • Ping: 259ms
My Question
I’m considering deploying FusionHub locally on a Protectli Vault to avoid the geographic routing penalty while still getting the bonding benefits and a public IP. However, I want to understand:
  1. What kind of performance impact should I expect from an on-premise FusionHub compared to direct internet access?
  2. Has anyone deployed FusionHub locally in Africa or similar distant regions and can share their experience with speed retention?
  3. What are the typical overhead percentages you’ve seen with local FusionHub deployments versus cloud-based ones?
  4. Are there any specific considerations for bonding links through a local FusionHub in terms of hardware requirements or configuration optimizations?
Additional Context
  • Primary use case: Reliable internet with static IP for business applications
  • Current connections: Multiple ISPs including Starlink
  • Location: Rwanda (significant distance from major AWS regions)
  • Hardware consideration: Protectli Vault for local FusionHub
Any insights from the community would be greatly appreciated! The AWS performance hit is quite substantial, and I’m hoping a local deployment will give me the reliability benefits of bonding without sacrificing so much throughput.
Thanks in advance for any guidance!
The 226ms latency when direct is interesting. Can you work out where the STarlink traffic is breaking out? Maybe a geoip lookup on the public IP you’re using when directly connected?
A fusionhub hosted close to where the Starlink traffic breaks out to the internet is what you want.
