I am trying to deploy the FusionHub.ova on ESXi 6.7 and getting the "Unhandled exception (1)! " message.
Am I missing something?
Thank you.
Thank you.
Downgraded the VMware to ESXi 6.5 - imported FusionHUB.ova OK (!!)
Problem solved, but what is it about the ESXi 6.7 ?
Hi VideoStream,
This appears it may be an issue with the build number. My ESXi server at home is currently running 6.7.0 Update 1 (Build 10302608) and I am able to deploy the FusionHub.ova file without issue. I will reach out to our engineers to see if they have run into this issue on the later builds of ESXi.
It appears that you may have run into an ESXi bug. This post shows an older build but it seems to still be something some users are running into.
One of the workarounds seems to be what you have done, downgraded to another version of ESXi.
Another workaround is downloading the ESXi 6.7 Offline Bundle and install this on the host. After you’ve done the install of the Offline Bundle, you will need to reboot the host for it to take effect.
Thank you, Zach
The VMware ESXi 6.5 work really well. i was able to import the FusionHub.ova and configure SpeedFusion in no time.
