Fusionhub on Laptop VM so I can leave BR1 at home for laptop travel?
I travel with a laptop and Carry a BR1 Mini 5g to fix poor hotel wifi by bonding 5g with SFC protect.
But my laptop already has a 5g card.
Can I run a Fusionhub on a VM locally for when I don’t have the BR1?
I.e. Given speedfusion connect app is only for android or Iphone, can I make a system that runs on my local machine bonding 2 connections to Speed Fusion Connect Protect (cloud SFC), by deploying Fusionhub on a VM on my local machine?
I.e Set up the Fusionhub as a client to Speedfusion Connect Protect servers and advertise a SFC tunneled LAN Connection on the local VM for my Laptop to connect to?
Will the dynamic weighted bonding and layer 3/4 benefits be lost? Given it is inside a VM I figure it won’t be as good as the BR1. I also understand the Antenna positions in the laptop will be poorer.
Could I use the quota I already have with my BR1 subscription?
After writing this I noticed on the fusionhub manual page 111 it says there is a maximum of 2 Network adapters, one for Lan and one for WAN. so I think this may kill the idea?
Hello, @Robert_S
Please… look at
Also…
No… The Fusion Hub is to be used at server inside a datacenter. Don’t have support to use multiple wans at same time.
No… Each device, must have his own quota for SFC subscription.
Correct.
