Hi all,
Can anyone please explain how it works if WAN throughput exceeds one’s FusionHub license limit?
I will use my situation as an example, where I have 2 x 13/1 Mbps and 1 x 10/0.5 Mbps connections, for total available bandwidth of 36/2.5 Mbps.
In regular load balancing mode, all 36 Mbps downstream and 2.5 Mbps upstream are available, but no more than 13/1 Mbps at a time, because the connections aren’t bonded.
Assuming I buy a FusionHub Essentials license, capped at 25 Mbps. Are the remaining 11 Mbps (36-25) of downstream bandwidth still available to be used by anyone else on the network?
I’ve looked extensively, but can’t work it out.
Thanks in advance, Edward
