FusionHub license expired. what to do?
Hi :
I have a Max Transit and a Fusionhub configuration. Both licenses show as expired. I renewed my Max Transit license and it now shows as available in incontrol2. However, the Fusionhub still shows as ‘expired’, and the connection to Fusionhub is down. What should I do to renew that license?
What version of fusion hub do you have? Where did you get from?
Firmware 8.1.1 build 4982
got it straight from the peplink site. On the incontrol dashboard, the ‘subscription expiry date’ shows ‘2022-02-05 (Expired)’
Hi @marcvl , FusionHub also requires InControl 2 subscription as your Transit router in order to work with InControl 2 services. Please renew its license if you want to use it with InControl 2.
Is this a solo version, or what version is it?
If you used incontrol2 to create the vpn tunnels then you need to renew the incontrol2 subscription.
If you want to renew it , send me a pm and I can help you renew it.
