Den
1
can someone help concerning the install a FusionHub within Hetzner VPS?
For Ionos it did work with an vmdk file but for Hetzner I don’t think so.
Can someone help, how to get the image inside Hetzner, so that I can start up a Hetzner VPS with FusionHub?
Ben_Ka
2
Hi Den,
I tried this aswell without success yet, even the Hetzner Support could not help to achieve this.
If you want to use Hetzner anyway I guess the only option is to rent a dedicated server there, which is around 30€/month and install proxmox there.
Best regards.
Ben
