Is it possible to deploy FusionHub in Azure Cloud?
Best Regards,
Ben
Best Regards,
Ben
if we setup FusionHub in another cloud service like AWS. Will FusionHub be used only as a hub for all our Balance routers or will we be able to access the networks of the cloud as well?
is there a way to test FusionHub?
Ben
You can use FusionHub to forward traffic between instances in the same AWS VPC and Balance routers by assigning FusionHub as Balance subnets’ gateway in AWS virtual private gateway.
Please follow instructions on page 62 of installation guide to test FusionHub in AWS:
