I’ve got some phased-out equipment from work, including a FusionHub license and a Balance 210.
My home network currently consists of an unmetered LTE connection plus a WISP, all through a MAX BR1 which feeds an eero. I’m hoping I may be able to add the Balance 210 and FusionHub to the mix to bond the two home connections.
However, I’m not certain what settings the FusionHub/SpeedFusion profile should use for this. What I’d ultimately like:
- FusionHub → [SpeedFusion: MAX BR1 + WISP connection] → Balance 210 → my home router (an eero
- I’d like the public WAN IP of the FusionHub to essentially be forwarded all the way down to the eero
Does that make sense? Is this possible?
Edit: if necessary, I have a secondary public IP available on the VPS hosting SpeedFusion.
