I am trying to install FusionHub on Amazon Web Services but the t1.micro instace that appears on the isntallation guide is not available on AWS.
Can you tell me how to select the t1.micro instance?
Thank you.
Best Regards,
Gorka
Thank you.
Best Regards,
Gorka
There is a note on Burstable performance instances - Amazon Elastic Compute Cloud :
The t1.micro is a previous generation instance and it has been replaced by the t2.micro, which has a much better performance profile. We recommend using the t2.micro instance type instead of the t1.micro. For more information, see T2 Instances.
So we shall update the documentation accordingly.
Than you Michael. The problem is that T2 instance is disabled for the FusionHub image. I solved the problem adding a new FusionHub image to EU (Ireland) region, it seems that the t1.micro instance is not available in EU (Frankfut) region.
Best Regards,
Gorka
