FusionHub 8.5.2 not accept PepVPN from AP One AC Mini
Yesterday, I upgraded FusionHub from 8.5.1 to 8.5.2. After that, AP One AC Mini can not connect to FusionHub. When I reboot FusionHub to 8.5.1 AP One can connect again.
AP One AC Mini HW 1 Firmware 3.6.3 (latest available)
Log from FusionHub 8.5.1 (AP One successfully connect to FusionHub)
Aug 09 21:33:16	SpeedFusion: XXXX (xxxx, sn:XXXX-YYYY-ZZZZ) connected to XXXX
Aug 09 21:32:54	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:32:40	WAN: connected (10.32.0.65/255.255.255.0 gateway:10.32.0.1 DNS server:10.32.0.1)
Aug 09 21:32:37	System: Started up (8.5.1 build 5246)
Aug 09 21:30:41	System: Reboot from Web
Log from FusionHub 8.5.2 (AP One keep trying to reconnect every minute)
Aug 09 21:29:54	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:28:54	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:27:54	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:26:54	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:25:59	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:25:04	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:24:14	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:23:29	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:22:44	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:22:04	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:21:24	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:20:49	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:20:19	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:19:49	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:19:24	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:18:59	SpeedFusion: Accepted TLSv1.2 connection from 49.49.xxx.yyy using cipher suite ECDHE-RSA-AES256-GCM-SHA384
Aug 09 21:18:51	WAN: connected (10.32.0.65/255.255.255.0 gateway:10.32.0.1 DNS server:10.32.0.1)
Aug 09 21:18:47	System: Started up (8.5.2 build 5282)
Aug 09 21:17:02	System: Reboot from Web
There is not log about PepVPN on AP One AC Mini.
I see Peplink firmware 8.5.2 mention that SpeedFusion VPN won’t connect with firmware 8.0.0 or below. But I don’t know if that apply to PepVPN or not. And Pepwave firmware version seems to be numbered differently from Peplink firmware. (Latest Pepwave firmware is version 3.9.5 which just released this year. However, this version does not issue for AP One AC Mini HW1)
Can AP One AC Mini HW1 connect to FusionHub 8.5.2 (or above)?
