Fusion Hub Solo asking for Speed fusion connnect license activation key
Hello I just started a new instance of Fusion Hub Solo on Vultr. I have two Prime care routers, and one essential care router attached using SpeedFusion VPN. I am using Speed Fusion relay to attach my phone using the speed fusion app. My question is just recently I saw the following “SpeedFusion Connect has been disabled. A new activation key is required to enable it again.” I am unsure what I need to do. As far as I can tell all the connections are still working. Since on the Hub there is a limited menu of options on the SF relay page does a new license enable all the features such as are on a peplink router? If anyone has experiece with this message please let me know what the steps are to fix it.
John
You can ignore this, SpeedFusion Connect is the paid service (that an amount of data comes with y our Primecare devices) that lets you endpoint a SpeedFusion connection at a datacenter on servers run by Peplink. Your Fusion Hub is doing that for you.
Frankly, I have no idea why anyone would want to connect a Fusion Hub to another, it is limited to 1 network connection so you couldn’t get any redundancy (past what your datacenter already has) anyways.
I assume that Peplink disabled it intentionally and this message is a result of that.
