I have Peplink and Virpinet in use and just can tell you that the new Licising Programm from Viprinet is “Pain in the Ass”.
The Virpinet Webinterface is also not the best what you can get in my Eyes. Very Bad Documentation of the Features. You have Millions Point hidden and not clear structured in the Menu of the Device. If you want to understand what´s going on or where you can “tune” something als Administrator you need to contact the Support to understand whats going on.
In compare to Peplink i just can say now, that i have more this “Controlles Feeling” as Administrator because i easily understand the Peplink Product and his Webinterface / Settings.
Did you ever get anywhere with finding a technical comparison for Peplink vs Cradlepoint?
I’ve also been asked about this and when I took the request to Peplink I was told it wasn’t something that they’d ever looked at, I have to say I found this to be quite a surprise, normally manufacturers are more than keen to point out deficiencies in the nearest competitors.
I was unable to get a document together for this comparison. They are on different upgrade paths so they leap frog each other with new functions as cellular routers but main differentiators are:
The HUGE range of products/technology that Peplink offers: SD WAN, Balance routers, Wi-Fi APs, FusionHub, SD Switches, Time and attendance Apps, etc. whereas CradlePoint is mainly a single cellular/single Ethernet router solution
SpeedFusion: Bonding, WAN Smoothing, HotFailover and all their excellent benefits
They both have a good cloud management tool (I think IC2 is better though and it does more as it has to interact with more products!)
I am sure others in the forum can chime in with their views!
