Hi Support,
I’m sure you’re well aware of bufferbloat, so I’m curious to know if you plan to add something like fq_codel to your firmware, or if you deem it appropriate at all given your market focus…
FWIW, I’ve found it to be quite appealing simply because of the fact that you don’t have to delve into defining a whole bunch or classes, priorities, rules, etc. – rather you just turn it “on” and “it just works” – a concept that would seemingly fit Peplink’s ethos very well.
Just curious to see your thoughts!
Trip
