Hi All,
Hope you are all well.
I am currently looking a way to route traffic through the secondary tunnel created which has WAN smoothing enabled.
Using SpeedFusion Cloud and I have ALL Supported VOIP Applications Enforced on that tunnel, however when I make a Whatsapp Call I can see that the service isn’t using that Tunnel, just going through the default tunnel.
Are they going to add Whatsapp into the Application Selection some time or another? Or the only way is to forward through 10 rules the ports that Whatsapp uses?
Thank you.
