I have a customer with a WAN IP address /30 and a block of /29 Public IP address to be used on LAN. I’ll like to know what configuration is suitable for forwarding LAN /29 IP address to the public. Not sure of Drop-In-Mode or Outbound Policy can do the magic.
With a /30 for routing the /29 public IP addresses, I would recommend IP forwarding on the WAN and outbound policy can do the magic. Under: Network> WAN> Connection Settings - click on the “?” next to Routing Mode to enable IP Forwarding.
Hi Ron,
Thank you for your response. I’ll try the IP Forwarding and get back.
Regards
any updates on this? i realize its old but i have a customer with same setup from AT&T, and I need to route public IPs to 5 suites using the balance 310 fiber 5g router that was recommended for this. I cannot find a way to do so and this example from draytek explains it well
