Hi all
I have packets arriving on a Peplink on a ethernet port. Note that the destination addresses of these packets is not the Peplink itself, but other devices in the same subnet. I need do forward these packets to several devies in a different subnet. For this, I would like to encapsulate these packets and send them to the broadcast address of the second subnet.
Any idea on how to do this?
Thanks!
I would try using UDP relay under Advanced > Misc Settings and see if that fits your needs.
That would be perfect for my needs, the only issue is that the data on subnetwork A is not broadcast. It would have to be re-packaged somehow into broadcast/multicast packets.
I think you need to explain what you’re trying to achieve at an application level first and then we can work out the traffic flows / routing.
If its not multicast traffic on source subnet A then what is it and why do devices on subnet B need it?
Private Message me if you need to be secret squirrel about it…
