Hoping to get some tips or advice. We currently have cable internet with Comcast with 1 static IP that connects to our head office which has Verizon fibre using our Fortigate 90D firewall which does a full tunnel VPN using preshared key. The head office authenticates also against the Comcast static IP address. This is a standard IPSec VPN.
We decided to remove the Comcast as it’s insanely slow and purchased a HD2 device with 2 AT&T SIM cards both with Static IP and then deployed FusionHub on Azure to do bonding because we need all outbound traffic to come from a dedicated IP address for the VPN. I set all traffic on the HD2 to go through the FusionHub VPN, and when doing online checks for my IP it shows my IP as the FusionHub IP address. I also updated the head end to FusionHub’s IP address instead of Comcasts.
The VPN will not connect though, and our head office device is saying it’s because the ports aren’t open. I then went into FusionHub and tried Port Forwarding, making 2 rules, one for all TCP ports and 1 for all UDP ports, and set them to forward to the IP address of the Fortigate 90D connected to the HD2. The HD2 is 192.168.200.1, and the Fortigate is 192.168.200.10, so I set it to forward all ports to 192.168.200.10.
This still doesn’t work, the Fortigate VPN will not connect with the head office saying ports are closed. I have a FTP server running on port 21 connected to the Fortigate 90D which is 192.168.200.12 and port forwards in the Fortigate as well as another server at 192.168.200.13 on port 90. If I connect via FTP to FusionHub’s public IP address it connects fine as expected, same with port 90 for the other server, which leads me to believe that I’m forwarding ports properly, as I can access servers connected directly to the Fortigate 90D, just not VPN through.
We also have Client VPN on the Fortigate 90D, but if I try to connect from a laptop remotely to FusionHub’s public IP address it’s the same issue, it never connects and says check that the ports are open. Been trying to make this work for a few days unsuccessfully so I feel like I’m doing something wrong.
Do I need to do something extra on the HD2 or FusionHub to make our VPN actually work like this?
