Hi all,
Any clues as to why force UDP encapsulation would be greyed out (un-tickable) when configuring an IPSec tunnel?
Hi all,
You need to enable NAT-Traversal, located on the top of IPsec profile list (If you’re editing your IPsec profile, save it first, and then you will see the option).
