I have a MAX-BR1-MINI-5GN-T-PRM and when I login to the Dashboard at https://mars.ic.peplink.com/ then the map shows me in Stamford CT.
- can I manually set my location in the Peplink dashboard?
- can I automatically set my location in the Peplink dashboard?
- if no for #1, then can I remove the map from my Peplink dashboard?
Thanks.
Hi…
Br1mini5G, don’t have GPS, but you can go to IC2, select your device and EDIT.
Address or Location…
Save
That is too much work for an RV on wheels.
It would be better to delete the map or peplink to get the GPS location from my Victron Cerbo GX.
You can get an API key for google or opencellid (which doesn’t really work) and have it do geolocation.
