I am running firmware version 6.3.0 on a Balance One Core, there is a new firmware version available 6.3.1. When I press the “Check for firmware” button, I get a message stating there is no update available. In fact in the last few years that I have used these routers I have never been able to update firmware this way. Has anyone else been able to update this way?
The reason I am doing this is because the manual upgrade method is failing. I have a very slow connection to this router, and the manual upgrade times out before the firmware file transfer is completed.
This is noted by engineering and we are re-working this feature. Assuming this is a manual upgrade being done remotely and not locally? Have you tried using InControl2 for the upgrade using firmware management?
Yes, firmware 6.3.1 is GA. The release date on the download page is the end of Feb. 2016. The feature to find new firmware on Peplink routers has never worked for me, and thats going back years.
