Hello, i have a friend to whom I recommended Pepwave. They purchased a BR1. Here are the details on the unit:
Model: MAX-BR1-LTE-E-T
Hardware Revision: 1
Current firmware: 6.1.1s55 build 1637
I’m having some difficulties with it, but before I report them I wanted to update to the latest firmware. I used the “Check for Firmware” of the web config utility of the device, and it reports there is no firmware upgrade available. Yet, when I look at your firmware web page under “Max BR1” (HW1), it looks like a firmware is available (6.3.5). Can you tell me whether or not this 6.3.5 firmware is compatible with this router ?
Yes, firmware 6.3.5 is compatible with the BR1 Hardware Revision 1. However, as you mention, you will need to download the firmware manually and upload it to the BR1. Here is a link to > Download < the firmware 6.3.5
