Firmware B210 HW4
Hi ,
I have a peplink b210 with a default firmware 6.1 , can i let my peplink with this firmware or i need to update it
What is the best firmware version that work perfectly on the B210
Thanks ,
I’d recommend the latest firmware that can be used on the hardware version of your B210. See https://www.peplink.com/support/downloads/ .
Unless you have HW1 (very old) you should be able to use ether latest version – 7.1.2.
8.0 is forthcoming but has not been released yet.
Thank you Rick , i appreciate your efforts
