Firmware 8.6.0 GA Announcement
Are we going to get an update to fix the SIP issue?
@Don_Ferrario ,
As mentioned by @Salvador_Almaguer, the issue has been identified and confirmed by the Engineering team, and we are currently working on a fix.
The issue is related to EAP-TLS authentication with WPA2-Enterprise Wi-Fi clients. In the reported case, the client sends a large EAP-TLS packet of around 1700 bytes, which becomes fragmented and causes the authentication issue.
For the issue you are experiencing, could you please create a support ticket so that we can verify whether it is related to the same issue?
This will also allow us to confirm that the fix covers your scenario and, once the firmware with the fix is available, we can arrange for you to verify it.
Thank You
