Firmware 8.5.2 Features
Hi Sir,
What are the key new features introduced in the firmware update from version 8.5.0 to 8.5.2?
Is there a presentation file or Powerpoint available for reference?
Have you looked at the release notes?
There are detailed notes on what issues have been addressed and what improvements have been made.
From my experiences both versions and version 8.5.1 has mainly improvements for overall stability.
You can find the release notes here:
8.5.0: https://download.peplink.com/resources/firmware-8.5.0-release-notes.pdf
8.5.1: PDF
8.5.2 RC1: https://download.peplink.com/resources/firmware-8.5.2rc1-release-notes.pdf
Hope this helps.
Hi Sir,
I know that version 8.5.0 introduced support for Starlink applications. What new applications were introduced in version 8.5.2?
The 8.5.2 will have the switch controller as new feature:
For the improvements see the full list in the release notes: https://download.peplink.com/resources/firmware-8.5.2rc1-release-notes.pdf
Hope this helps.
Hi Sir,
I got it , Thanks.
Regard,
Bit.
