Firmware 8.5.0 - Support for 802.11k and 802.11v
I want to be sure I’m taking advantage of the new WiFi Support features that were released with firmware 8.5.0. Specifically Assisted Roaming for Managed APs & Wi-Fi WAN Support for 802.11k and 802.11v.
Is there any instruction available to follow to insure these features are being taken advantage of? I’ve updated my router and AP with the most recent firmware releases.
You can check to see if Assisted roaming is on by going to the following location on your router.
After, scroll to the bottom and you should see the following below.
Please let me know if this helped.
Respectfully,
Chris
Thanks, that’s easy enough. I assume the settings of Conservative, Moderate or Aggressive set the threshold for switching between APs?
