We are pleased to announce that Firmware 8.5.0 RC 2 is now available.
I see a past note ‘Added support for Least Used algorithm for Mobile Internet/Cellular WAN in Outbound Policy.’ Any plans to do the same for the VDSL FlexModule as well?
Will the RC2 of the 8.5.0 resolve the Starlink related issues?
has the VDSL module monitoring/reboot (and follow on event log of that) from s148 made it in 8.5.0? I didn’t see it in the release notes.
According to the Release Notes it should be fixed.
I hope this version fixes the LACP connections broken under 8.4.1. Also, if better logging was provided it would help. - Without this basic functionality, the support for multi-giga bandwidth is useless.
Also support for services groups (port groups) would help management a lot. It’s been almost 15 years waiting for that basic feature that most other brands support.
Also, exporting/importing the firewall rules would help tremendously. The lack of these basic features make us reconsider other options.
|32362|[RC 2] [System] Added Remote User Access network support to UDP Relay|All Models|
Should the Remote User Access network now appear as an option in Bonjour Forwarding Settings as well? My understanding, which might be incorrect, is that Bonjour forwarding is a particular kind of UDP relay.
UDP Relay to the Remote User Access network isn’t working for me.
I configured forwarding of multicast 224.0.0.251:5353 between a number of VLANs, and I can ping my printer by its *.local name from clients in other VLANs using the local AP, but I can’t ping it when I leave home and connect via L2TP.
