outbound openVPN is working by IP BUT it does not work for domain names, for example, i have a rule in that plex.bz must go out over vpn, the rule is there, but does not work.
Has anyone else noticed that when accessing a factory default device running 8.2.0 through IC2 remote web admin, youâre now prompted to change the default SSID password in the same way youâre prompted to change the default web admin password when logging in for the first time from the LAN?
Weâd love to see an option to accept the default password on each of these pages, that way it can be left unchanged if the user wishes not to change it. Of course itâs not advised to use default passwords, but there are plenty of instances where changing it upon first login is not desired. Maybe 3 options even. âchange nowâ, âremind me next time I log inâ, and âignoreâ to account for different scenarios.
This has resolved some issues I was having with the Max Adapter connected to a Balance 20x, sims would stay fixed on 3G and not change to LTE when it was available, it appears to be working well on this release.
Is Peplink aware of the Apple Homekit issues with the new Beta Release version?
Does firmware team care or investigate?
@ckirch ,
Do you have a ticket open for the issue ? Itâs best that support team can check on this and review the your setup for the issues.
For the OpenVPN outbound policy, may I know itâs working using 8.1.3 GA firmware or you just tested using 8.2.0 and itâs not working as expected ?
For the domain outbound policy, the device will learn the domain name IPs via the LAN devices DNS request and the IPs returned by the DNS servers. Seen you have only 1 source IP need to access the plex.bz via the OpenVPN. Potential the DNS records have been cached by the Client device 192.168.20.190 and the domain outbound policy the not taking effect based on the rules. Can you help to open a ticket for support team to further analyze the DNS resolve for your setup ? This will able to help us to know why the outbound policy not taking effect .
@Topher ,
We have updated the released notes to reflect to the 8.2.0 Beta1 changes for the enforce WIFI AP password change.
I reverted to 8.1.3 and itâs still happening, I disabled dns cache on the router, and also flushed it on my clients, it still doesnât not work with new ip requests. Iâll open a ticket after GA, thanks
Issue found on Balance 20x (HW1) on previous stable and this beta version, you cannot select âoptimal network discoveryâ when using a 5G Flexmodule, it errors when saving the configuration with âunsupported value: cellular sim optimalnetworkâ and optimal discovery has to be unticked to save the configuration. I have a ticket open on the issue as I discovered the same issue on 8.1.3 build 5060 code.
@cgreen, thanks for reporting this. I saw our technical support is following up with you in the ticket.
Using a Pepwave BR1 Pro 5G - I opened the Wi-Fi WAN to choose a Wi-Fi wan network. I am not sure what the default sort order is but I had to click the Signal Strength column header to show me the strongest first. I suggest the default sort order is by signal strength. I assume itâs being sorted by name. Iâm not sure thatâs how other devices such as iPhoneâs sort.
