We’re happy to announce that the Firmware 8.0.1 RC1 is now available.
Supported models:
EPX, Balance, MAX, SpeedFusion Engine, FusionHub, Surf SOHO
Supported models:
Same issue here. Signal works for Cell but no WiFi
The UI fix should be included in the next RC build, stay tuned.
thanks. curious if anyone is seeing cpu load issues on this RC? i keep seeing it go to 100% cpu. it did not have high cpu in 8.0 release.
Would you able to open a ticket for us to check ? or can you PM me the SN & enable RA access for your device for us to further check ?
just submitted a ticket and messaged you the ticket #
Hello @sitloongs,
We are seeing high CPU loads also on one unit running 8.0.1 RC1, I will PM you the SN.
Happy to Help,
Marcus ![]()
Ok
Hi Guys!
Can you please share when will the First Packet Inspection for Office 365 be ready?
Thanks!
High CPU issue identified and it will be fix for coming 8.0.1 RC2 firmware.
Thank you for helping to verify the RC firmware.
Thank you!!
This topic was automatically closed after 9 hours. New replies are no longer allowed.
