Pepwave Surf SOHO MK3
7.1.0 build 1284
Please upgrade to this special firmware.
https://download.peplink.com/firmware/br1ac/fw-max_br1mk2_hotspot_sohomk3-7.1.0s026-build1291.bin
Alternatively, you may try v7.1.1b02
https://download.peplink.com/firmware/br1ac/fw-max_br1mk2_hotspot_sohomk3-7.1.1b02-build1326.bin
I tried the first link and it worked! Thanks for your fast and helpful reply! ![]()
I have a Surf Soho HW1. The firmware page shows it is supposed to work with version 7.1.2 but when I try to update it says the file size is too big.
Is it not supported even though the site says it should be?
Thanks!
Hi orenyny,
only for the SOHO MK3 is the 7.1.2 available, for the older HW1 without MK3 not!
Try to logon to the Router an klick on “Check for Firmware”
Regards
Dennis
