We use a Peplink Balance 580 with Firmware 6.2.0 and a Peplink Balance 310 with Firmware 5.4.9.
The Maschine 580 has 2 Cable, 3 ADSL and one LTE Wan connections. LTE is disconnected at the moment.
The Maschine 310 has 1 Cable and 2 ADSL connections.
Before, we used on both sides Firmware 5.4.9 with no problems.
But because of the new LTE-Stick, we needed to do an upgrade on the 580 Maschine up to 6.2.0.
After this we have every 2,3 days strange problems.
Mostly the way, that WAN connections, who went off will not come back running the SpeedFusionTunnel.
Example:
3 days ago
The LTE-Stick proberly has been offline for some reason.
But went back online again. Status was green.
But looking in the SpeedFusion Status, the LTE-Connection was still red.
And making problems, wich concern the whole tunnel.
My solution was, to kick the LTE-Connection out of the tunnel und later
put it back. So it was running again.
Today
We had a problem with 2 ADSL connection. To much packet loss.
To we had to reboot to DSL-Modems. After this, the DSL-Connection
was coming back, but they did not show up in SpeedyFusionTunnel again.
Here some pictures.
This behavior is unknown for me, in firmware 5.4.9.
Thx for this Info.
Now, after two days testing 6.2.0 and 6.2.1, I´m sorry to inform you the following:
Still problems WAN connections not coming back up in the tunnel
DSL Connection is online, Speedy Fusion Status showed it as down.
So I´m going back to 5.4.9, because it´s stable.
This doesn’t look normal on firmware 6.x, can you open a support ticket (http://cs.peplink.com/contact/support/) for our team to take closer look at the units?
I´ll make an upgrade on both sides up to 6.2.1.
And some more tests on Friday, if they fail, I´ll ask for support.
Thanks for free upgrade the firmware.
BTW: How can I get besser SpeedFusion Performance.
I have two 12 Mbit Uplinks on one Side.
With one 12 Mbit Link, I get 12.
But with two online, I get only a little bit more so 13 to max 14.
Testing this all with SpeedFusion test.
Only with the UDP Test, i can push this up.
This is all on 5.4.9 Firmware.
Today I made it. Upgrade both sides to 6.2.1 and …
Christmas and Easter on one day.
Perfect Performance up to 26,7 Mbits Upload.
I made some unordinary tests, but the tunnel was coming always back, with
all online WAN connections.
Thx for this wonderful firmware.
Everythink is fine now.
