nuno1
1
Hi There,
I just installed firmware 6.2 RC in 2 Surf Soho and one B380
Everything seams to be working fine, but in Surf Soho, even if the PEPVPN is established, the profile is gone in the respective place.
And in B380, what is missing is the Host/IP Address for the VPN Profiles
If you need some more information, don’t hesitate to ask. I tried to insert here the pictures, it was not possible.
BR
Nuno Olivença
TK_Liew
2
Hi Nuno,
Please open ticket for us to investigate.
Thank you.
I think I have same thing today with b380 and SOHO.
[Ticket #749019] PepVPN / speedfusion on 6.2.GA
Hi Andrey,
Your case under investigation. We will update you on the finding.
nuno1
5
If you find the reason, I am also interested in the solution. probably it will be a new build/release with the bug solved…
BR
Nuno
Latest 6.2 doesnt’ seams to have this problem
Download from here:
