I’m looking for having some kind of firewall and filtering rules on the FusionHub to prevent some peers to see each other. Is this possible on the current FusionHub firmware?
No possible now. There is “Remote Network Isolation” option that disable inter-routing between ALL peers. Work around is do not advertise those routes in Balance and use outbound policy to enforce those subnets go through FusionHub.
Hi Guys,
I need to ask to put this feature in your roadmap. this is some scenarios when you want to block some peers to access each other but not all of them. the network isolation is blocking all peers and is not good for many cases.
