Hello , we have Rules set for firewall to block some sites and applications , but when looking for logs, they are not shown as events.
is there a way to enable logging for Firewall ?
Thank you!
If you go in to the firewall rule you just need to check the box to enable event logging. Hope this helps.
thank you ,
so would need to apply globally to the initial Rule that was created to reflect on all devices under the rule
