I am debugging some routing issues I have with my system and I am trying to figure out at what speed the LAN ports are actually connecting at. I can not find this under any status menu or any other menu. Is there a menu that shows if the wired LAN ports are connection at 10/100/1000?
In the manual for the LED pattern it says the following but no mention of 1000
LAN and Ethernet WAN Ports
Green LED ON 10 / 100 Mbps
Orange LED Blinking Data is transferring
OFF No data is being transferred or port is not
connected
Port type Auto MDI/MDI-X ports
Ken
