Filtering routing updates
Can we configure a Peplink router to ignore routes to specific networks advertised by a VPN peer over the tunnel?
Hello…
Yes… you can.
Here you are controlling what routes to advertise. I want to control what advertised routes I can ignore after I receive them.
Possible (untested) workaround… on the device where you want to ignore a received route, add a static route on the Network tab so that there’s already a more local route. That might override the received route? You’d probably need to exclude that static route from being advertised too.
